PC headset to ICOM 7600 connector
Posted by wa3ltj on 2024-03-05 at 19:50Where do I find a correct diagram from wiring a PC headset (2 separate stereo 3.5mm plugs) to the microphone jack of an Icom 7600?
wa3ltj replied 2 years, 4 months ago 2 Members · 2 Replies -
292
Always with the easy questions 😅
Unless I’m missing something, none of the microphone pins are outputs. Bizarre. I found the connections here: https://www.manualslib.com/manual/1278421/Icom-Ic-7600.html?page=26
Also check page 27.
In the words of my buddy Andy, am I missing something?
manualslib.com
Microphone Connector Information - Icom IC-7600 Instruction Manual [Page 26]
Icom IC-7600 Manual Online: Microphone Connector Information. (Front panel view) q Microphone input w 8 V DC output e Frequency up/down Microphones D HM-36 D SM-50 (option) 23 i Main readout AF output (varies with [AF]) u GND (Microphone ground) … Continue reading
25
Yes. There was a typo. Corrected to: “diagram for wiring a PC headset” I am not looking for pin-outs of connectors. Lacking a diagram, I will work from the pin-outs and make (and test) my own diagram.
Where do I find a correct diagram for wiring a PC headset (2 separate stereo 3.5mm plugs) to the microphone jack of an Icom 7600?
